Prośba o interpretacje błędów VAG
  • Prośba o interpretacje błędów VAG
    A to na 3,5ara da sie dom postawic ??
    Oooo zero się zjadło chodzi o 30,5 :P
  • #2
    Witam dziś kupiłem kabel do diagnostyki i z czytałem błędy ale wiem jak je interpretować pomożecie?
    uesday,20,January,2015,22:00:09:62939
    VCDS Version: Release 12.12.0 (x64)
    Address 01: Engine Labels: 03G-906-016-BKC.lbl
    Control Module Part Number: 03G 906 021 LR HW: 03G 906 021 AN
    Component and/or Version: R4 1,9L EDC G000SG 9248
    Software Coding: 0000071
    Work Shop Code: WSC 66565 257 00032
    VCID: 7AFB1463352A82CEDA7-802F
    2 Faults Found:
    005785 - Powertrain Data Bus
    P1699 - 000 - Missing Message from Steering Wheel Electronics
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 113727 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 21:58:59
    Freeze Frame:
    RPM: 0 /min
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 12.16 V
    Bin. Bits: 11001100
    Bin. Bits: 00000000
    (no units): 0.0
    049448 - No Communications with Parking Brake Control Module
    U0128 - 000 -
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 113727 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 21:58:59
    Freeze Frame:
    RPM: 0 /min
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 12.16 V
    Bin. Bits: 11001100
    Torque: 0.0 Nm
    Torque: 351.4 Nm
    Readiness: 0 0 0 0 1
    Tuesday,20,January,2015,22:01:23:62939
    Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
    Control Module Part Number: 1K0 907 379 P
    Component and/or Version: ASR FRONT MK70 0105
    Software Coding: 0017025
    Work Shop Code: WSC 73430 790 00000
    VCID: 3F8DA5776E8867E6AD9-806A
    1 Fault Found:
    01314 - Engine Control Module
    013 - Check DTC Memory – Intermittent
    Tuesday,20,January,2015,22:01:58:62939
    Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
    Control Module Part Number: 1K0 963 235 E HW: 1K0 963 235 E
    Component and/or Version: PTC-Element 0404
    Software Coding:
    Work Shop Code: WSC 00000 000 00000
    VCID: 2D51EF3FB4E4E5760F5-8078
    1 Fault Found:
    00361 - Heater Element for Auxiliary Heater (Z35)
    014 - Defective
    • #3
      Zamieszczone przez rado84
      005785
      Forum - Octavia Club Polska
      049448
      049448 - Brak komunikacji ze sterownikiem elektrycznego hamulca postojowego
      01314
      Link
      00361
      • #4
        rado84, wystarczy trochę poszukać.. pierwszy błąd już masz na ocp...
        Resztę też zapewne znajdziesz... a jak nie to wtedy forumowicze na pewno pomogą
        edit
        piotrek_os, był szybszy 8)
        • #5
          dzięki za pomoc,
          wychodzi na to że jak sprawdzali mechanicy auto coś przekodowali - nie mam tempomatu i wcześniej błędu nie było.
          nagrzewnice da się naprawić więc super.
          brak komunikacji z sterownikiem elektrycznym hamulca nie rozumiem bo mam manualny ręczny więc ciekawe skąd taki błąd.
          najbardziej martwi mnie błąd 01314. podejrzewam słaby akumulator - tej zimy auto unieruchomione. Ale dlaczego przy tym błędzie ASR się zaświeca?
          • #6
            ktoś dokodował do gatewaya, że jest taki sterownik, stąd błąd...
            to żaden błąd - mówi po prostu, że w sterowniku silnika są błędy i to jest prawda bo są i to odnoszące się do hamulca postojowego - ma to związek z ABS
            ... podświadomie myślę, że ktoś wsadził sterownik silnika z Passata B6, tylko po co?
            • #7
              tylko że ja mam problem z asr jak sie zapali to nie gaśnie. Ciekawe czy można zapisać błędy które w trakcie jazdy się pojawią. Czytam instr. może coś tam znajdę.
              ps. kolo który dodawał mi kluczyk sporo się umęczył, mówił że coś z kompem jest nie tak. Więc może przez to.
              • #8
                bo to może być przez to, że jest zakodowany ten hamulec....
                wykasuj sobie błędy - przejdź się autem i znów zrób autoscan
                • #9
                  Koledzy myślałem że będą nowe błędy przy zawieszeniu się ASR a okazało się że system nie działa kontrolka świeci się ciągle a komp nie wyrzuca błędów co jest grane poniżej cały autoscan
                  Data version: 20130910
                  Friday,23,January,2015,20:24:14:62939
                  Chassis Type: XX (1K0)
                  Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 62 72 76 7D
                  VIN: XXXXXXXXXXXXXXXXX Mileage: 113750km/70680miles
                  00-Steering Angle Sensor -- Status: OK 0000
                  01-Engine -- Status: Malfunction 0010
                  03-ABS Brakes -- Status: Malfunction 0010
                  08-Auto HVAC -- Status: OK 0000
                  09-Cent. Elect. -- Status: OK 0000
                  15-Airbags -- Status: OK 0000
                  16-Steering wheel -- Status: OK 0000
                  17-Instruments -- Status: OK 0000
                  19-CAN Gateway -- Status: OK 0000
                  25-Immobilizer -- Status: OK 0000
                  42-Door Elect, Driver -- Status: OK 0000
                  44-Steering Assist -- Status: OK 0000
                  46-Central Conv. -- Status: OK 0000
                  52-Door Elect, Pass. -- Status: OK 0000
                  62-Door, Rear Left -- Status: OK 0000
                  72-Door, Rear Right -- Status: OK 0000
                  76-Park Assist -- Status: OK 0000
                  7D-Aux. Heat -- Status: Malfunction 0010
                  Part No SW: 03G 906 021 LR HW: 03G 906 021 AN
                  Component: R4 1,9L EDC G000SG 9248
                  Revision: --H08--- Serial number: XXXXXXXXXXXXXX
                  Coding: 0000071
                  Shop #: WSC 66565 257 00032
                  3 Faults Found:
                  Freeze Frame:
                  Fault Priority: 0
                  Fault Frequency: 11
                  Reset counter: 255
                  Mileage: 113727 km
                  Time Indication: 0
                  Date: 2000.00.00
                  Time: 21:58:59
                  Freeze Frame:
                  RPM: 0 /min
                  Speed: 0.0 km/h
                  Load: 0.0 %
                  Voltage: 12.16 V
                  Bin. Bits: 11001100
                  Bin. Bits: 00000000
                  (no units): 0.0
                  U0128 - 000 -
                  Freeze Frame:
                  Fault Priority: 0
                  Fault Frequency: 11
                  Reset counter: 255
                  Mileage: 113727 km
                  Time Indication: 0
                  Date: 2000.00.00
                  Time: 21:58:59
                  Freeze Frame:
                  RPM: 0 /min
                  Speed: 0.0 km/h
                  Load: 0.0 %
                  Voltage: 12.16 V
                  Bin. Bits: 11001100
                  Torque: 0.0 Nm
                  Torque: 351.4 Nm
                  005379 - Load Signal from Alternator Term. DF
                  P1503 - 000 - Implausible Signal
                  Freeze Frame:
                  Fault Priority: 0
                  Fault Frequency: 1
                  Reset counter: 255
                  Mileage: 113742 km
                  Time Indication: 0
                  Date: 2000.00.00
                  Time: 19:37:01
                  Freeze Frame:
                  RPM: 798 /min
                  Speed: 18.0 km/h
                  Load: 0.0 %
                  Voltage: 14.52 V
                  Bin. Bits: 11001100
                  Load: 0.0 %
                  Bin. Bits: 00100001
                  Part No: 1K0 907 379 P
                  Component: ASR FRONT MK70 0105
                  Coding: 0017025
                  Shop #: WSC 73430 790 00000
                  1 Fault Found:
                  Address 08: Auto HVAC Labels: 1K0-820-047.lbl
                  Part No: 1Z0 820 047 D
                  Component: Climatic PQ35 010 0301
                  Shop #: WSC 00000 000 00000
                  VCID: 3467FA5B57CEB4BE40B-8061
                  No fault code found.
                  Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
                  Part No SW: 3C0 937 049 E HW: 3C0 937 049 E
                  Component: Bordnetz-SG H37 1002
                  Revision: 00H37000 Serial number: 00000003950960
                  Coding: 01880F030004140000110D000000000000087F075C
                  VCID: 2B55E1278AF0EB46111-807E
                  Subsystem 1 - Part No: 1Z1 955 119 A Labels: 1KX-955-119.CLB
                  Component: Wischer SK351 012 0401
                  Coding: 00065525
                  Shop #: WSC 73430
                  Address 15: Airbags Labels: 1K0-909-605.lbl
                  Part No SW: 1K0 909 605 R HW: 1K0 909 605 R
                  Component: Q2 AIRBAG VW8 018 2200
                  Revision: 02018000 Serial number: 0038MD09PAFJ
                  Coding: 0020786
                  VCID: 3B75D1677A907BC6811-806E
                  Subsystem 1 - Serial number: 6332MSME0D16146DF
                  Subsystem 2 - Serial number: 6342MSME100B6500
                  Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
                  Part No SW: 1K0 953 549 AF HW: 1K0 953 549 AF
                  Component: Lenksäulenmodul 034 0070
                  Coding: 0000012
                  VCID: 76E300530132E6AEBEF-8023
                  Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
                  Part No: 1Z0 920 810 E
                  Component: KOMBIINSTRUMENT VD1 3564
                  Coding: 0003101
                  Shop #: WSC 80093 222 69422
                  Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
                  Part No SW: 1K0 907 530 F HW: 1K0 907 951
                  Component: Gateway H10 0120
                  Revision: H10 Serial number: 28001062161693
                  Coding: 3D3F0F00071302
                  VCID: 2A5BE423850AF24EEA7-807F
                  Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
                  Component: IMMO 3564
                  Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
                  Part No: 1T0 959 701 B
                  Component: Tuer-SG 024 2345
                  Coding: 0000244
                  VCID: 3663C05341B2A6AE7EF-8063
                  Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
                  Part No: 1K1 909 144 K
                  Component: EPS_ZFLS Kl.5 D06 1701
                  VCID: 3365F94752C0B386591-8066
                  Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
                  Part No: 1K0 959 433 AK
                  Component: KSG 0401
                  Coding: 00D002007F2D8505084F010004CC
                  Shop #: WSC 00046 046 52295
                  VCID: 79F90B6F302C89D6D3D-802C
                  Subsystem 1 - Component: Sounder n.mounted
                  Subsystem 2 - Component: NGS n.mounted
                  Subsystem 3 - Component: IRUE n.mounted
                  Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
                  Part No: 1T0 959 702 B
                  Coding: 0000252
                  VCID: 377DCD5746B85FA6659-8062
                  Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
                  Part No: 1K0 959 703 E
                  Component: Tuer-SG 021 2435
                  Coding: 0000144
                  VCID: 326BFC43ADDABA8E527-8067
                  Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
                  Part No: 1K0 959 704 E
                  Coding: 0000144
                  Address 76: Park Assist Labels: 1Z0-919-283.lbl
                  Part No SW: 1Z0 919 283 B HW: 1Z0 919 283 B
                  Component: Parkhilfe 4-Kan H04 0020
                  Coding: 0000001
                  VCID: 3D71DF7F648475F6BF5-8068
                  Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
                  Component: PTC-Element 0404
                  Revision: 00800000 Serial number:
                  2 Faults Found:
                  014 - Defective
                  01299 - Diagnostic Interface for Data Bus (J533)
                  End ---------------------------------------------------------------------
                  POWRÓT NA GÓRĘ
